6/5/2020 2:11 PM | |
Joined: 3/19/2020 Last visit: 6/29/2024 Posts: 28 Rating:
Hi, You can also use wincc runtime advance or wincc runtime proffessional. Regards, Nilesh |
6/5/2020 2:16 PM | |
Joined: 2/5/2013 Last visit: 6/13/2024 Posts: 320 Rating:
This links will be helpful to you. S7 1200 FW version and Model Number? Delivery release TIA Portal V16 SIMATIC STEP 7 including Safety and WinCC V16 TRIAL download Updates for STEP 7 V16, S7-PLCSIM V16 and WinCC V16 Br, AmolG. |
6/5/2020 2:31 PM | |
Joined: 9/27/2006 Last visit: 6/29/2024 Posts: 12264 Rating:
Hello @shish; Wincc V14 professional RT is no longer available for download, only versions 16 and 15 SP1 can be downloaded as a trial version (21 days runtime). To obtain a Wincc V14 professional RT license and software you should contact your nearest Siemens rep, and be able to discuss with him the tag license and options you require. https://support.industry.siemens.com/cs/ww/en/view/109739719 Hope this helps, Daniel; Chartier |
6/6/2020 5:54 AM | |
Joined: 9/16/2011 Last visit: 6/20/2024 Posts: 291 Rating:
Hello dchartier, Thank you for your reply. Guide me on this. 1. presently, i am using TIA V14. Can i upgrade it to V15 or V16? else do i have to uninstall the V14 and then v16 to install. please provide the link. 2. Do i need to install a separate software for WinCC professional or will it be installed with TIA V16 itself? 3. After upgrading to V16, will i be able to work with my older programs which was prepared in V14? Reg, @shish |
