Default Header
(0)| 2/16/2009 10:48 PM | |
Posts: 2661 Rating:
Hi Ross, If you meant 1600x1050 (for instance) for the second 1280x1024 in your post, the typical problem I have seen with this kind of scenario is the objects seem stretched and look "ugly". You need to run the OS Project editor with proper resolution. See the following FAQ: How do you use a monitor with a 1680x1050 pixel resolution with the OS project editor? |
