Default Header
(0)| 5/14/2013 11:47 AM | |
Posts: 1530 Rating:
Hello 1marin9, unfortunately I have no experience with SICAM PAS but I suppose it should work quite the same way as in WinCC. I suppose that you have to connect tag.value. You should have a look at variables of structure tagand their format. I C-Script you also have to take equal format and for IO-field it should be the same. You are telling that IO-field bescomes dim. Does this mean field besomes grey, or "stars" in it. Maybe you could add an attachment with your scripts and settings for IO-field. Where is your IO-field located? By random I found this: What should you watch out for in particular when using WinCC structure types? Best regards Bizur |
| 6/2/2021 5:42 AM | |
Posts: 4 Rating:
check out this it may help:-https://youtu.be/zv8Wna8IOfc
