(0)| 5/5/2009 10:48 AM | |
Hello Navnag; For a first look, I have found over 200 hits on the Siemens portal (automation.siemens.com) when Searching on ATEX certification (EU directive on explosive environments, if I remember correctly): https://www.automation.siemens.com/_en/portal/search.htm?searchFor=ATEX+certification&siteID=1&x=14&y=15 That should give you an idea of the range of equipment Siemens can provide for offshore applications. You could also look at this link, from the Siemens Oil and Gas division, describing success stories from different projects, inculding offshore drilling and production: http://www.industry.siemens.com/oil%2Dgas/en/ Hope this helps, Daniel Chartier |
