5/16/2023 10:23 AM | |
Joined: 9/16/2019 Last visit: 9/2/2025 Posts: 56 Rating:
Thanks Murof. I also played around and could not find a solution. I will have to implement an alternative solution |
5/23/2023 11:55 AM | |
Joined: 8/3/2009 Last visit: 9/10/2025 Posts: 16386 Rating:
Hello BobZA Yes every tag reference in a screenwindow (-> screen) will be used with the tagprefix. If you want to make exceptions then you can use @NOTP for example (https://support.industry.siemens.com/cs/ww/en/view/109792585/129462634507) -> and this works also with a struct on the faceplate instance Bye Murof |
