Default Header
(0)| 6/25/2009 8:51 AM | |
Posts: 37 Rating:
Hi all, I encountered this message from diagnose folder while running WinCC 6.2. // WinCC reported exception with code: C0000005 ACCESS_VIOLATION // Date: 12.6.2009 - Time: 17.37.10 // Caused at logical address 77D043A5 01:000033A5 //==================================================================== // FAULTING MODULE: C:\WINNT\system32\OLEAUT32.dll //==================================================================== // Registers: // ---------- // EAX:00300030 // EBX:02E24748 // ECX:0000180C // EDX:00000000 // ESI:02D8B728 // EDI:00000048 // CS:EIP:001B:77D043A5 // SS:ESP:0023:0849FE4C EBP:0849FE58 // DS:0023 ES:0023 FS:003B GS:0000 // Flags:00010206 // // Call stack: // ----------- // Address | Frame | // ---------+----------+---------------------------------------------- // 77D043A5 | 0849FE58 | VariantClear+55 // 00C748E0 | 0849FE7C | 0001:000038E0 C:\Program Files\Siemens\WinCC\bin\CCDmRtServer.DLL // 00C7870F | 0849FE88 | 0001:0000770F C:\Program Files\Siemens\WinCC\bin\CCDmRtServer.DLL // 00C7802D | 0849FEA8 | 0001:0000702D C:\Program Files\Siemens\WinCC\bin\CCDmRtServer.DLL // 00C71BCF | 0849FED0 | 0001:00000BCF C:\Program Files\Siemens\WinCC\bin\CCDmRtServer.DLL // 00C72DEA | 0849FEE8 | 0001:00001DEA C:\Program Files\Siemens\WinCC\bin\CCDmRtServer.DLL // 00C784AF | 0849FEF4 | 0001:000074AF C:\Program Files\Siemens\WinCC\bin\CCDmRtServer.DLL // 00C7848D | 0849FF14 | 0001:0000748D C:\Program Files\Siemens\WinCC\bin\CCDmRtServer.DLL // 00C8FA4A | 0849FF28 | DllUnregisterServer+B7DB // 00C8FB61 | 0849FF50 | DllUnregisterServer+B8F2 // 00D32059 | 0849FF84 | DllUnregisterServer+ADDEA // 77BCB530 | 0849FFB8 | endthreadex+A3 // 77E66063 | 0849FFEC | GetModuleFileNameA+EB After it, WinCC just hung and we have to restart the whole system. This is troublesome for our customer. Any idea about this? I also attached the whole Diagnose file just in case. Thanks a lot for your help. :) AttachmentDiagnose.zip (228 Downloads) |
| 6/25/2009 9:11 AM | |
Joined: 3/21/2006 Last visit: 1/10/2026 Posts: 10247 Rating:
Hello kid_26, If we assume this is Windows problem (put OLEAUT32.DLL in Google), you can try with Mcrepair.exe http://download.microsoft.com/download/msninvestor/patch/1.0/win98/en-...mcrepai Hope this will helps. Best regards Hristo Mihalev |
| 6/25/2009 9:26 AM | |
Posts: 37 Rating:
HI Umencho, Thanks for your fast response. Does the error have anything to do with CCDmRTServer.dll? What affects this dll file? Thanks. :) |
