Default Header
(1)| 3/30/2012 5:52 AM | |
Posts: 2964 Rating:
Hello.... SimocomU is the software which used only for the 611u and 611UE series of card only!!!!! For connecting it with 840D 611D control card is used.... Does your 840D is connected with PCU20/PCU50 ??? it is PCU50 you can do the NC side commissioning from the main screen itself because HMI Advanced will be present If it is PCU20 you need to have HMI advanced PC-PG software for communicating it. You need to have laptop with MPI port available and you need to use MPI cable for commnicating it. Refer DOCONweb for more informations link attached... https://www.automation.siemens.com/doconweb/content.asp?item=2735&cd=sinumerik_simodrive_04_2010_e&scope=all Regards, Prakash |
