Default Header
(0)| 3/28/2007 4:24 PM | |
Posts: 1 Rating:
I have controller with protocol IEC 60870-5-101 master, how get data (Tag Value) from WinCC by protocol IEC 60870-5-101 Slave. |
| 3/28/2007 6:41 PM | |
Posts: 1275 Rating:
You want to get the data from this controller into WinCC? Which is this controller? Are you using OPC? I think that could be a good way.. check this out. There are some OPC for IEC. I just found that one in google. Maybe you should look for a solution like that. Or maybe you could use a IEC - Profibus gateway, like this. |
Last edited by: Danielle at: 28.03.2007 18:48Last edited by: Danielle at: 28.03.2007 18:47Last edited by: Danielle at: 28.03.2007 18:43 |
