Default Header
(0)| 12/24/2012 10:36 AM | |
Posts: 2964 Rating:
Hello, Does it is CNC machine / standalone 611A drive ? Have you tried removing the flat band cable(ribbon cable)and checked... try switching on the IR module alone and check... Check this link may be useful /tf/WW/en/Posts/51046 Regards, Prakash |
| 12/26/2012 5:16 AM | |
Posts: 2964 Rating:
Hello, You can find the informations in the DOCON WEB link.. check it https://www.automation.siemens.com/doconweb/content.asp?item=12410&cd=sinumerik_simodrive_04_2010_e&scope=all Could you also check any special type of timers are used inside the machine... Check your relays and harware timers Regards, Prakash |
