Default Header
(0)| 1/31/2014 11:07 AM | |
Posts: 267 Rating:
Hello, you can get access to the PLC only with an IPin the subnet mask of the PLC. So you can give your iPad/iPhone a static addresswhich is in the subnet mask of yourWLAN access point and the PLC. Or if the access point supportes DHCP, you use this and tell the accesss pointto give your iPad/iPhone an IP address in the subnet mask of the PLC. Do you know this: http://support.automation.siemens.com/WW/view/en/74819592 |
