12/26/2009 6:10 PM | |
Posts: 1 Rating:
isnt it possible to communicate s71200 and Wincc 7.0 ?? i can ping to my plc but wincc says no connection to the plc.. |
12/26/2009 7:44 PM | |
Joined: 12/22/2006 Last visit: 1/25/2022 Posts: 1742 Rating:
Hello, If I refer to this link: http://support.automation.siemens.com/WW/view/en/38051469 it seems not possible to do it directly. |
12/28/2009 11:05 AM | |
Joined: 9/23/2005 Last visit: 8/27/2025 Posts: 4416 Rating:
Hi, once it is possible to connect S7-1200 with SIMATICNET using OPC interface, ( http://support.automation.siemens.com/WW/view/en/39960680) you can use this interface to connect WinCC to S7-1200 |
Denilson Pegaia |
12/29/2009 2:06 PM | |
Joined: 11/29/2009 Last visit: 1/13/2025 Posts: 19 Rating:
Hi! When we connect the WinCC to S7-1200, can we use this (sendind and receiving information)through TCP? |
4/20/2010 8:18 AM | |
Posts: 26 Rating:
Hello, I can access all links... glubb |
4/21/2010 10:31 PM | |
Posts: 37 Rating:
Thanks Pegaia for your usual support and cooperation. glubb , please follow the attached PDF that explain how to set up the OPC “step-by-step”. Once you configure the OPC, try to configure the WinCC as in the attached screenshot. I have tested, working okay.. Cheers AttachmentS71200.zip (1565 Downloads) |
9/20/2014 9:28 AM | |
Joined: 1/14/2013 Last visit: 8/7/2025 Posts: 2 Rating:
Hey MANS, Nitin |
