(0)| 2/5/2018 12:34 PM | |
Posts: 36 Rating:
Hi, a question about interfacing IOT with MS SQL. It seems that MS SQL Server ODBC driver for Linux is not available for IOT2000 platform. MS seems to release these drivers only for different platforms. Where to find a suitable MS SQL diver for nanodbc on IOT2000? Note: ODBCCPP library is GPL-ed so not usable in my closed source program. Its seems that TDS is another way to connect MS SQL without using drivers. Does someone know a suitable library without GPL license? Other solutions? Thanks! ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 2/6/2018 9:49:26 AMNew subject after splitting |
| 3/2/2018 11:07 AM | |
Joined: 4/28/2015 Last visit: 1/15/2026 Posts: 3345 Rating:
Hi, apart from TDS I've found SQLAPI++ but this is only free for evaluation purposes.. Maybe this is suitable for you? EDIT: If you want to use node-red there are several nodes for using a MSSQL database (e.g this one) Best regards! |
Last edited by: bergmanu at: 3/2/2018 11:32:44 AMNot working for IOT2050 support anymore from March 1st, 2024. |
