Default Header
(0)| 8/26/2008 5:37 PM | |
Posts: 24 Rating:
Are there any problem for CPU, programs of PLC if I use other USB/RS485 cable, like this one: http://www.3onedata.com/Product_Info.asp?ProductID=177 |
| 8/27/2008 11:55 AM | |
Posts: 49 Rating:
Hi, Why bother, the Siemens part is cheap enough, for panel use it'd small enough to tuck into the trunking, or you can use a DIN adapter to mount it. The only time I've used something different was to interface with a Battery monitor at TTL levels, and then I built my own. Marc Sinclair http://s7-200.germainesystems.eu |
Last edited by: marcsinclair at: 8/27/2008 1:33 PMlink Last edited by: marcsinclair at: 8/27/2008 11:56 AMSpelling |
