Default Header
(0)| 1/13/2009 1:47 PM | |
Posts: 335 Rating:
Can I manually assign the time stamp of an "ALARM_S" message? |
| 1/13/2009 8:30 PM | |
Posts: 2661 Rating:
You can use the Associated Value (Parameter SD). |
| 1/14/2009 7:05 AM | |
Posts: 335 Rating:
So,how can Iapply the time of message which I manually set in PLC to"WinCC alarm control"? |
| 1/14/2009 3:51 PM | |
Posts: 993 Rating:
Hello SM That should helps you: http://support.automation.siemens.com/WW/view/en/23730649 regards cumulus |
