Default Header
(0)| 5/30/2011 7:57 AM | |
Posts: 487 Rating:
Hi It fairly easy to connect win cc to a database en read or write records. Just search for SQL database in this forum and you will find the way to connect to a database You can also surf to http://www.w3schools.com/Sql/ You can read a tag : value1 = HMIRuntime.Tags("LPC_WINCC::PO_NR0" & XX).Read you can then write it to a table = INSERT INTO table_name VALUES (value1, value2, value3,...) Eric |
| 12/14/2020 9:01 PM | |
Joined: 9/13/2012 Last visit: 10/6/2025 Posts: 1 Rating:
Hello Friend, can you provide an example of this application?
