(0)| 1/25/2021 10:05 AM | |
Joined: 10/10/2014 Last visit: 12/8/2025 Posts: 1725 Rating:
Hi alex288, From the User Archie Editor you have 2 posibiltys to export any data From Edit -> Export, Import or Right Mause on archive Archive Data Save to File, Load from File Also you can export archive data from User Archvie Control See How is the data from a user archive filtered, sorted and exported in Runtime? https://support.industry.siemens.com/cs/ww/en/view/10095491 How can you export and import data records of a WinCC user archive? https://support.industry.siemens.com/cs/ww/en/view/8972156 Please not try to delete the File ProjectOpende.lck ! This file is created from WinCC to avoid multiple access. This file you have to delete only it the WinCC runtime is deactivated and WinCC Explorer is closed ! Best regards schufri |
| 1/25/2021 10:11 AM | |
Posts: 7298 Rating:
Hello alex288, does the Userarchive-Server (Process "CCUsrAcv.exe") run ?
Georg Berghof |
