(0)| 4/12/2021 2:56 PM | |
Joined: 10/10/2005 Last visit: 1/29/2025 Posts: 1940 Rating:
Hello Benesd, is the FB dependent of other FBs or FCs, example with CALL-instruction? It could be also a time stamp conflict. I recommend to check the block-consistency and compile and download again. See also the FAQ: How do you perform a block-consistency check following changes in the STEP 7 program? Otherwise I recommend also to update the firmware version of the CPU. With best regardsCicero |
