(0)| 5/15/2021 6:30 PM | |
Posts: 4 Rating:
Hi everyone I’m trying to simulation but the CPU signal light have not on, how can I do?
| 5/16/2021 2:56 PM | |
Joined: 9/27/2006 Last visit: 1/14/2026 Posts: 12481 Rating:
Hello JJ; Are you still asking how to download the hardware configuration and the PLC program to the simulated PLC with S7-PLCSIM? The PLCSIM v5.4 manual explains the issue quite well: https://support.industry.siemens.com/cs/ww/en/view/54667828/14016888203 Hope this helps, |
| 5/16/2021 4:43 PM | |
Posts: 4 Rating:
Hi Daniel Yer I have try to down the program to the simulated but it alway show 33:16662
| 5/16/2021 9:23 PM | |
Hello JJ; Your picture is not readable, we cannot see what the message is. either make a real screenshot or copy the text if yu want us to understand what you see. Here is a document showing the explanations for error codes for a S7-300 PLC: https://support.industry.siemens.com/cs/ww/en/view/770453 Based on ths error code. something in your setup is not correct. Your hardware configuration does not select a proper CPU, or you have given it a wrong MPI address, or you have selected the wrong network/access point for a PLCSIM connection. Review your configuration with the help of the PLCSIM manual already shown; open the Troubleshooting Tips.section. Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 05/16/2021 21:23:54Last edited by: dchartier at: 05/16/2021 22:13:01 |
| 5/17/2021 2:41 PM | |
Joined: 3/11/2019 Last visit: 1/7/2026 Posts: 1653 Rating:
Hi JJ1984, the "status LEDs" of plcsim must work, if not, plcsim does not work. There are several posts in the forum for this, always a complete deinstallation of plcsim was neccessary. Only an update will not work. 1. please deinstall plcsim v5.4 via windows control panel (also if the latest version is already installed) 2. reboot the system 3. install plcsim v5.4 sp8 update 1 again Afterwards the LEDs should be shown an plcsim should work again. Trial Software SIMATIC S7-PLCSIM V5.4 SP8 including Updatesregards sancruz |
Last edited by: sancruz at: 05/17/2021 14:43:06Feedback appreciated, please rate |
