(0)| 9/4/2021 5:14 PM | |
Joined: 9/27/2006 Last visit: 12/19/2025 Posts: 12467 Rating:
Hello bishoui; In STL you can setup a grouping of instructions that you want to call at a later point in your program, either conditionnally or unconditionally. To identify these grouping of instructions, you use a Label. In your case m02b: is a label that you point to with a Jump instruction. An STL label is 4 characters long and must start with a letter. The screenshot below explains it better than I can, it is taken from the STL for S7-300/400 manual: https://support.industry.siemens.com/cs/ww/en/view/109751814 Hope this helps, Daniel Chartier |
