Default Header
(1)| 4/7/2006 9:45 AM | |
Posts: 57 Rating:
Hello! Has anybody managed to connect TP177A on DP port on CPU313C-2DP? How do you configure it...? Kolma |
| 4/10/2006 8:24 AM | |
Posts: 1611 Rating:
Hi, it should be the same like all other panels. Did you have the manual for the TP177A? http://support.automation.siemens.com/WW/view/de/21084461/0/en What settings did you use at the Panel and PLC? Did you have this problem with other panels too? It it s your first project? |
