(0)| 1/14/2023 11:56 AM | |
Posts: 4 Rating:
Thank you for your reply. Control card on Infeed module? Yes? what is the difference between modules A B C version? can they be swapped?Thank You. |
| 1/15/2023 3:38 AM | |
Posts: 8092 Rating:
Yes. |
| 1/15/2023 5:10 AM | |
Joined: 10/17/2007 Last visit: 12/23/2025 Posts: 4566 Rating:
See the infeed module basic drawing . T. 72 is a NO contact of small relay. --if you checked all enabling and you all drives are no problem (drive status transfer back to infeed from device bus) --your yellow LED on ,your green LED off?--- if everything ok as you said it is possible that small relay has issue. I suggest --NOT replace control card for Infeed (it is not like drive--card and power section removable ) --you need replace the whole infeed module to trouble shooting --then send bad module to repair shop the infeed module version A,B or C will compatible if power rating same
AttachmentInfeed Module basic drawing.pdf (1207 Downloads) |
If you like my comments please |
