(0)| 12/20/2023 9:54 PM | |
Joined: 9/27/2006 Last visit: 1/12/2026 Posts: 12480 Rating:
Hello; Looking for PC 677B in the SIOS, you will only find a Product phase-out announcement, with a suggestion for replacement with an IPC677C; Looking for IPC 677C, you find a Product phase-out announcement, with a suggestion for replacement with an IPC677D; Looking for IPC 677D, you find a Product phase-out announcement, with a suggestion for replacement with an IPC677E, finally. https://support.industry.siemens.com/cs/ca/en/view/109802876 The chain of successor modules from your PC 677B leads to the IPC677E, so that does look like the most likely path. If you need to look at the specifications for the IPC677E, you can find them here: https://support.industry.siemens.com/cs/ca/en/view/109769668 Hope this helps, Daniel Chartier |
| 12/21/2023 11:55 AM | |
Joined: 8/3/2009 Last visit: 1/9/2026 Posts: 16629 Rating:
Hello which Application do you use on these PCs? Of course you also have to consider the OS compatibility to your application: https://support.industry.siemens.com/cs/ww/en/view/64847781 Bye Murof |
