(1)| 9/21/2014 7:31 PM | |
Posts: 3 Rating:
Hi Carl S, I had the same problem and your solution worked for me. Thanks a lot for the solution!! Regards Sajkat |
| 6/13/2017 8:07 PM | |
Posts: 2 Rating:
I had the same problem and managed to solve it by removing the HMI and adding it again!!! I'm using TIA v14 and KTP1000 Basic. |
| 2/6/2024 7:39 AM | |
Posts: 2 Rating:
I am using Wincc Professional v17 i also faced the same issue. but in my case i have used a space in-between a variable name after correcting that it got solved |
