(0)| 1/19/2024 1:29 PM | |
Joined: 5/6/2022 Last visit: 1/15/2026 Posts: 589 Rating:
Hi R_Nelson, What is the LED that flashes exactly? Does anything appear on the monitor or is anything displayed? What IPC model exactly is it, can you indicate the reference? A priori, it seems that the IPC gets stuck in the later phase of the BIOS. This could mean that some important hardware component is unreachable or defective. Can you answer the previous questions? Best regards! |
