(0)| 2/22/2024 9:22 AM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello hajleh94 You shoudl check if you have the right data installed on your system (Images, files...) for doing the Image Update on the Panel. Check here, there is a good overview: https://support.industry.siemens.com/cs/de/en/view/109746530 In newer Image Versions you can also perform a OS Update on the Panel directly with external memory device Bye Murof |
