(0)| 3/21/2024 6:03 PM | |
Hello; Are you using a Sirius Safety relay 3SK2112- xxxxx in your project? If this is the case, you should install ths software (trial license): - SIRIUS Safety ES V17 (TIA Portal) https://support.industry.siemens.com/cs/ca/en/view/109793090 If this not a product you use, pleae mention any equipment (from Siemens) tha would reqire its own specialized configuration software. Hope this helps, Daniel Charter |
| 3/21/2024 9:12 PM | |
Posts: 5 Rating:
Thanks for your help. Best Regards, Hamza DAĞ |
| 9/27/2025 9:42 PM | |
Joined: 9/27/2025 Last visit: 1/11/2026 Posts: 1 Rating:
Olá, também estou com esse no meu Tia portal v19, como posso resolver? |
| 9/28/2025 12:17 PM | |
Translation from the Portuguese text:
Olá ; Os participantes do fórum da Siemens são de muitos países e muitos não entendem português. Para facilitar o entendimento entre os membros, escolhemos o inglês como idioma de intercâmbio. Por favor, tente escrever em inglês na sua próxima visita. Hello; Participants in the Siemens forum come from many countries, and many do not understand Portuguese. To make understanding easier between members we have selected English as an interchange language. Please try to write in English on your next visit. If you have the same problem as described earlier, which Sirius safety relay model are you using in your project, and what version of Sirius Safety ES v19 have you installed on your programming PC? Here is a link to Sirius Safety ES software and licenses: https://support.industry.siemens.com/cs/ca/en/view/109821435 If this is not the problem you are facing, please take the time to describe it here for us. Hope this helps, Daniel Chartier |
