4/24/2024 8:48 AM | |
Joined: 4/28/2015 Last visit: 9/11/2025 Posts: 29 Rating:
Hello Chris, Do you know if this applicable for Windows 11 as well? as we face the same issue. Best regards, Ahmad |
4/24/2024 9:35 AM | |
Joined: 10/12/2023 Last visit: 9/12/2025 Posts: 119 Rating:
Well, If you have problems with access to website, WebApp: See if you have configured IIS and ARR correctly. IIS things (roles, features) to be installed attached in screens (help from my last project). If you still have problem, try to delete Website from IIS manager, then open GMSInstaller from DCC Install files again. If website not showing, you need to create it manually. Info about create it manually below: https://superuser.com/questions/825580/what-exactly-is-default-website Then it should work. If u have problem with Flex Client URL, it´s loading but when typing login/pass message "No connection" shows up, you need to reconfigure your port (if it´s local IIS so 443) by one tool, from DCC Instal files/Additional. Info in Access Flex Client word document attached. AttachmentAccess Flex Client.docx (663 Downloads) |
Last edited by: Jen_Moderator at: 04/24/2024 12:08:01Text formatting optimized. Best regards, |
