(0)| 10/2/2024 11:50 AM | |
Joined: 12/6/2023 Last visit: 7/25/2025 Posts: 3 Rating:
After installing TIA 18 update 4, all other versions of Tia Portal (13 through 17) work correctly, but when closing the project this attached pop-up appears. The project is saved and closed correctly, but the crash warning continues to appear. Projects in TIA 18 on the other hand are closed without this pop-up appearing. It happens on both local pc and virtual machine. The only way to make this behavior disappear, is to return the machine to the state before installing TIA 18 update 4 version. Any recommendations? AttachmentPopup.zip (214 Downloads) |
| 10/2/2024 11:54 AM | |
Joined: 5/12/2006 Last visit: 1/14/2026 Posts: 22800 Rating:
hi, can you attach or open the report and post a screen maybe is the same problem like described here |
| 10/3/2024 8:51 AM | |
Solved adding the missing dll files. Thanks |
