(0)| 10/15/2024 12:23 AM | |
Joined: 11/22/2018 Last visit: 11/6/2024 Posts: 1 Rating:
TIA_Portal_STEP7_Prof_Safety_WINCC_Adv_Unified_V18 couldn't be installed with the following error: ERROR AdsWorkerForeignExe::GetInstallResult(): - 300: assuming unknown error, because return value <> 0 and either OK- nor ERROR-values are defined. Please check the corresponding log file for more detailed information FAIL! StartApplAfter (TIAP18::[INSTALLDIR]BIN\SIEMENS.AUTOMATION.GENERATOR.FRAMEWORK.EXEMODIFIEDC:\ProgramData\Siemens\Automation\Logfiles\Setup\)Failed How can I solve the problem? AttachmentSIA_STEP7_S7FPLUS_WINCC_ADV_V18@24-10-11_16-30-19_txt.txt (206 Downloads) |
