(0)| 2/6/2025 8:47 AM | |
Joined: 5/6/2022 Last visit: 1/15/2026 Posts: 589 Rating:
Hi Bobco, I have been doing some testing on my TIA Portal but I have some questions: - What version of TIA Portal are you using exactly to work with? - What packages do you have installed in TIA Portal? - Are you simulating or are you running the normal RT? - It is not clear to me what ' icons at the bottom of the object', do you mean those of the object in RT? I attach a screenshot of the ones I indicate. Looking forward to your clarification on these points!
| 2/10/2025 2:39 PM | |
Joined: 12/2/2009 Last visit: 12/1/2025 Posts: 46 Rating:
Hi ElonksuM_SN_BN, I'm using TIA Portal v15. The problem is on the TP700 Comfort Panel (no simulation). The disabled icons of the object are highlighted in the enclosed image. Thanks. |
| 2/10/2025 2:40 PM | |
