(0)| 2/20/2025 1:18 PM | |
Joined: 3/8/2017 Last visit: 1/7/2026 Posts: 18 Rating:
Hi, what you are having set up right now is a PoC (proof of concept) environment which is only for local use. The proxy settings will not change that. In order to connect an IED to the IEM via Internet you need a different approach where you need to involve your IT department and host the IEM centrally with all security or VPN matters that come attached with this. A simpler and faster way to achieve your desired scenario would be to order the IEM Cloud, which is a no-headache IEM in the cloud as a service solution. The IED will only need an outgoing connection from its location and you are good to go. I hope this gives a little bit of insight about the complexity of your project and discuss possible solutions with the responsible people. In case you need further project support you can contact your local Siemens representative. |
