5/2/2025 10:37 AM | |
Joined: 9/21/2012 Last visit: 9/16/2025 Posts: 4711 Rating:
You set the NTP server in each PLC and HMI. Here's a document that refers to 1500 series. Time synchronization with an online NTP server for SIMATIC S7-1500 Controller |
5/13/2025 5:52 AM | |
Joined: 5/29/2014 Last visit: 9/4/2025 Posts: 72 Rating:
You can program an S7 PLC to be a SNTP server using this library: Then you can point your other devices to the IP address of that PLC, as you described, and it should work to synchronise their times. I used the SNTP server from this library once in a project a few years ago and it worked fine, at least for S7-1500 PLCs (I didn't have HMIs in that project) |
