(0)| 3/9/2015 8:37 AM | |
Posts: 1 Rating:
Hi everyone I am manually migrating S7-200 programs to S7-1200, but have gotten a bit stuck with the use of SM0.6. BBPrudente's solution may work well for a Profinet clock, but I need a bit that reacts exactly like SM0.6, so that I can increment a counter conditionally on each alternate scan cycle. Does anyone maybe have an idea of how to do this reliably? Or is there possibly a similar functionality to SM0.6 on the S7-1200? Any help would be much appreciated. Best regards, Norval
Last edited by: Min_Moderator at: 3/9/2015 3:11:52 PMNew subject after splitting |
| 9/7/2021 1:52 AM | |
Joined: 6/12/2019 Last visit: 12/14/2025 Posts: 4 Rating:
Migrating S7-200 programs to S7-1200Hi S7-200 to S7-1200 TIA portal Program is Easily Migrate Possible with TIA v11 or TIA V11 SP2 You Need to Install TIA v11 and S7-1200 SIMATIC S7-200 to SIMATIC S7-1200 software conversion tool, This tested ok done this at window 7 64Bit You following this Steps as I have attached in Screen Shots 1- Install TIA Portal v11 2- Install TIA Migration tool and S7-200 to S7-1200 Conversion Tool 3- then Restart completer and Show Option S7-200 Migration in TIA V11 |
| 8/16/2025 3:53 AM | |
Joined: 4/18/2025 Last visit: 8/16/2025 Posts: 1 Rating:
any one have this tool plc tell me s7 200 to tia portal |
