(0)| 1/16/2010 8:20 PM | |
Posts: 14 Rating:
Hi all What are the applications in which this block can be used? Any Help will be greatly appreciated. |
| 1/16/2010 9:55 PM | |
Joined: 9/27/2006 Last visit: 1/14/2026 Posts: 12480 Rating:
Hello mhs100; It has been a very long while since I worked with a CPU 314IFM, and I no longer have a copy of projects we had developped unfortunately. At the time, we used the application examples for positionningfound in this manual (Inegrated functions of CPUs 312IFM and 314IFM) to understand how to use SFB 39. http://support.automation.siemens.com/WW/view/en/1086951 I trust you can use them in the same way. Hope this helps, Daniel Chartier |
| 1/17/2010 7:56 AM | |
Posts: 14 Rating:
Hi again |
| 1/17/2010 11:19 AM | |
Posts: 14 Rating:
Hi Umencho Then if i want to check the program using this block then how can i check it? |
