Default Header
(0)| 8/3/2010 3:20 PM | |
Posts: 39 Rating:
Hello Berg, The function block witch You need is part of LTpCam library. You need import it to Your scout project. 1. add Script folder to Your project 2. right click on it, chose ASCII Import... 3. indicate to SEB_Script_V1_4_1.txt 4. run the SEB_Script_V1_4_1.txt script 5. indicate to SEBUnit folder 6. import LTpCam library. Complete step by step manual You find in the archive. There are also Print Mark Correction function block manual. Let me know if any problem, Regards, Simon Attachmentseb.zip (539 Downloads) |
