Default Header
(1)| 1/5/2011 6:55 PM | |
Joined: 3/21/2006 Last visit: 10/16/2025 Posts: 10239 Rating:
Perhaps if you use this option How can you back up the actual values of DBs and bit memories? and then to re write... Best regards, Hristo Mihalev |
| 1/5/2011 8:19 PM | |
Joined: 1/28/2009 Last visit: 12/24/2025 Posts: 6885 Rating:
Dear member If the content of DB is the setpoints and analog value limits which are fixe over a period of time, loosing this data may cause problem of tuning process parameters again.To avoid so this is a feasible propose. Simply upload online project, create new element in DB and then download, no data loss. Check similar discussion here:
BR |
