(0)| 11/14/2011 12:47 PM | |
Joined: 8/31/2010 Last visit: 12/6/2025 Posts: 1525 Rating:
Hello alen23, You can simply make use of COMPARE Function and specify your string on both the sides of comparison. In your case make the incoming string as a variable (mapped to a memory) and compare with the string constant (ref string) which you want. You can make the reference string as a variable. More information on COMPARE instruction for S7-1200 is available here. |
Like it? Rate it! |
| 11/14/2011 7:04 PM | |
Dear alen23, You can check the String operation instructions from here, which may be helpful. |
Like it? Rate it! |
