(0)| 1/30/2007 9:38 AM | |
Joined: 4/24/2006 Last visit: 1/9/2026 Posts: 9104 Rating:
Hello hgq, Have you seen this faq: http://support.automation.siemens.com/WW/view/en/22701694 Hope it will help you, Best regards, Wizard |
| 1/30/2007 1:24 PM | |
Hello hgq, When you're connected to the panel through ethernet, which is running the programmed project. You should be able to browse for OPC variables. What version of WinCC flexible are you using: 2005 + sp1 + hf6? See following link: http://support.automation.siemens.com/WW/view/en/24376196 Have you tried to perform an OS update with panel? Be aware: to transfer license OPC-serverfirst back to PC Best regards, Wizard |
