Default Header
(1)| 11/26/2012 6:03 PM | |
Posts: 17 Rating:
Thank you TomDeWoufor your answer. You are absolute write! When I go to the Station Configuration Editor, after enabled the C:\ partition protection by EWF, the Station seems to be locked (enable/disable button is in gray color and theStation disabled). In this condiction I can only downloadhw and prog to the WinLC RTX F, because my configuration files are saved in the D:\ partition (unlocked by EWF). If I disableback the protection to the C:\, restarting the SIMATIC IPC and going again to the Station Configuration Editor, the station button is enabled itself so I can enable the Station again. Protecting the C:\ partition again, causes a new station lock. Itseems tobe normal when using EWF. I did not saw anyeffect in my application yet. Thanks a lot |
