Default Header
(0)| 1/24/2013 12:48 PM | |
Posts: 3609 Rating:
Import of a Technical Question of the User douglasgimenez
| 1/24/2013 1:06 PM | |
Hello, There is a FAQ that explains a bit more i think: How can you avoid overwriting the flags that are allocated for system and clock memory bits in the user program? Once sm byte is selected in CPU properties, you can use them as any other bit. First scan you can use to initialize things at startup. Pulse you can use to blink a light. Regards, Marcjan |
Problem solved? |
