(2)| 6/26/2013 8:36 AM | |
Posts: 559 Rating:
Dear Emil747, Please go to the below link Converting S7-200 to S7-1200: SM0.0 SM0.1 and SM0.5 You will get the answer for the same. |
| 10/2/2013 10:24 AM | |
Posts: 48 Rating:
I still cant get it to work, I need the sm0.5 function. anyone know how to make this work? |
| 10/2/2013 10:34 AM | |
Hello, Sm0.5 is a 1Hz clockbit in the 200 system. Your 1200 has also these clockbits. How can you avoid overwriting the flags that are allocated for system and clock memory bits in the user program? There you see where to find them and how to enable. You can choose the start address of the clockbyte yourself, so if you use MB0, M0.5 will be your 1 HZ clock Regards, Marcjan |
Last edited by: Marcjan at: 10/2/2013 10:44 AMLast edited by: Marcjan at: 10/2/2013 10:40 AMProblem solved? |
