Default Header
(0)| 4/1/2014 5:09 PM | |
Posts: 4620 Rating:
Hi Lupenquarto, mmmmhhh I do not know if some of our friends of this forum will give you a solution also because you have to check 192 points simultaneously? take a look at how many inputs you have available: What is the maximum number of inputs and outputs that can be addressed on the LOGO!? I rather think that there is some kind of instrument which will do this job, or you've already looked in that direction? Only for suggestion: easy-wire Harness Test System (Harness Tester/Cable Tester) |
| 4/7/2014 5:31 PM | |
Posts: 215 Rating:
Hi Lupenquarto, is it possible to post more details? Which way are you going to checkthe the connection? regards |
