4/21/2013 9:19 AM | |
Posts: 35 Rating:
HI All, I am facing some strange behaviour with Wincc V11 Advanced SP2 upd5 It happened two days back, I was configuring the HMI normally. And I went Online found the Runtime was strange. In the Block Icon and Faceplates all the Status were displayed wrongly. I have taken a screen shot of the same, can find it in the attachment. It was working fine, all of a sudden it became like this. Not sure what could be the problem. Need some solutions for this because I have come across the same problem in a different project too. Regards, V. Vignesh AttachmentRuntime_Problem.zip (309 Downloads) |
4/25/2013 3:07 PM | |
Posts: 35 Rating:
HI Tweety, I have updated the Pictures for your reference. My Problem is The status of the Icons and Faceplates are not correct. It was working fine, all of a sudden it changed the status. It would be a great help if you can fix this. I am not sure whether is this a problem with the Software itself?????? Thanks in Advance.... Regards, V. Vignesh AttachmentProblem_Updated.zip (313 Downloads) |
4/29/2013 1:04 PM | |
Posts: 3037 Rating:
Hello, Do you solve your problem? I have found this link for faceplate with WinCC Advanced. Configuration instruction for creating faceplates with WinCC Comfort or WinCC Advanced Tweety |
5/6/2013 12:27 PM | |
Posts: 35 Rating:
Dear Tweety, I didnt solve the problem. I used a old Backup and started working with it. I was not able to find a solution for that. Regards, V. Vignesh
4/9/2014 10:51 AM | |
Joined: 10/3/2013 Last visit: 4/5/2022 Posts: 6 Rating:
Hello, I faced the same problem. After rebuilding the software everything was okay again. Regards, Frank |
4/9/2014 1:00 PM | |
Joined: 11/15/2006 Last visit: 3/26/2025 Posts: 1319 Rating:
@Frank: I guess you mean 'Rebuild all'. Just to make clear what you meant. |
Have Fun! |
