Default Header
11/4/2013 6:48 PM | |
Joined: 4/30/2011 Last visit: 1/9/2022 Posts: 223 Rating:
I have no errors! when calling the script, it just resets the value of the DTL tag (Instead writes the system time)
11/15/2013 3:48 PM | |
Posts: 1299 Rating:
Hello AndyNeva, did you solve your problem? If you didn't you can start asupport request, I'm pretty sure they can help you. K!ke |
4/11/2014 4:40 AM | |
Posts: 28 Rating:
is there a solution for this problem, i need to write current date time to a tag in tia 12 using wincc advance comfort panel tp1200 |
