Default Header
(0)| 9/11/2007 11:19 PM | |
Posts: 2 Rating:
Hi, I need conect a CP1430 TCP with a WinCC v6.0. How isit made the program from this CP and WinCC? Thanks, BestRegards Ricardo |
| 9/12/2007 12:00 AM | |
Posts: 5822 Rating:
Hello, to connect a WinCC to a S5 you may use different ways, one would be to use a OPC Server for Send / Receive with ISO on TCP Protocol and a WinCC OPC Channel. Another way would be to use the PMC Channel by IT4 Industry, check here for more: http://www.industry.siemens.com/IT4Industry/EN/SOLUTION_SERVICES/SIMATIC_ADDONS/KANAL.HTM The Programming for the S5 can be found in the Samples delivered with the NCM COM Software. Best regards J_Bell |
