(4)| 7/23/2014 6:03 PM | |
Joined: 6/13/2006 Last visit: 12/12/2025 Posts: 123 Rating:
Hi Pabst, perhaps you can use the JMP_LIST or SWITCH command instead (s. attachement). You'll find the complete manual here. Regarrds, not_my_fault AttachmentD:\tmp\STEP_7_Basic_V13.0_-_JMP_LIST__Define_jump_list.pdf (770 Downloads) |
| 7/24/2014 10:30 AM | |
Posts: 3 Rating:
Thanks for the reply, here is what i was thinking: |
| 7/24/2014 12:33 PM | |
Posts: 5225 Rating:
The jump list does what you are thinking to do.. please have a look at the given documentation. (Thank you "not_my_fault".. this one is your fault [smile]). Alternatively you spend several netoworks for the task. Please also consider using CASE in the SCL language.. that is very powerful to use for what you need it for. Cheers. w |
| 7/25/2014 6:40 AM | |
Posts: 3 Rating:
Thank you William B. i will do that. |
