(11)| 12/3/2014 4:04 PM | |
Joined: 7/7/2010 Last visit: 1/15/2026 Posts: 16370 Rating:
Years ago when I first started using TIA Portal, I created a setup with the area coordination using Portal and WinCC Flex 2008, and later, with Portal and integrated WinCC HMI projects. I use the area pointer configuration in a DB called - oddly enough - HMI. I create a structure at the very beginning of the DB with all the HMI specific area coordination words in a single structure. I already had a zip with a sample configuration. Today I added another set of screen shots of how i use it. 3 jpg's inside the zip. AttachmentHMI_Area_Coordination.zip (1003 Downloads) |
| 12/3/2014 9:28 PM | |
Posts: 56 Rating:
Awesome. Thank you VERY much! |
