(0)| 3/30/2016 11:06 AM | |
Posts: 63 Rating:
Any one? |
| 4/15/2016 10:23 AM | |
Posts: 1250 Rating:
You pass a pointer to the DB |
| 4/15/2016 10:31 AM | |
Joined: 5/28/2008 Last visit: 1/15/2026 Posts: 1344 Rating:
The TO object is not a defined PLC-datatype. So far, your are not able to parameterize this in the IN/OUT Interface. Also VARIANT is not possible because of that. Absolute pointer is also not possible, because TO object has optimized access. Furthermore, absolute pointer is not state of the art and not symbolic. Of course, if you get rid of the TO object and read your counter directly via Status- and Controlword it would be possible. But the you loose the advantage of the TO object and need to program everything manuelly. See this FAQ https://support.industry.siemens.com/cs/ww/en/view/109475835 |
| 4/15/2016 11:38 AM | |
Posts: 1250 Rating:
Are we talking about the same thing? Drag a HSC object to an FB and set DB as single instance. Then use a pointer to that DB and pass it as variant. |
