Default Header
(0)| 8/31/2005 2:11 PM | |
Joined: 8/10/2005 Last visit: 4/9/2024 Posts: 1486 Rating:
Hardware: You need a printer with a serial interface or an adapter serial/parallel. Then you can connect CPU200 with the PPI cable to it. I don´t know a printer type or an adapter for this. Software: FREEPORT is the correct way to program it. I found a FAQ for printers and CPU200. May be you find additional infos there (tip 19): http://support.automation.siemens.com/WW/news/en/1232912 Kind regards Technical Support |
