Default Header
(0)| 3/29/2017 8:59 PM | |
Posts: 4 Rating:
Hi Friend! Good afternoon! You have two steps to do your application! STEP1: For write a variable value in a file you can just use node-red combined S7-Node with Storage file, like the print attached Node-red-text-file.png. Note: All the Node-red's text files has been created in /home/root/ directory. STEP2: You can write a code in C/C++ on Eclipse for interpret this file, here is a example how to read a text file with C++ code. I hope I've helped! |
